what stand do i use.?
the rear stand will mount to your swing arm. If your swing arm has a threaded tabs on both sides of the swing arm, you get the spools and attach them to the threaded tabs. If your swing arm does not have threaded tabs on the side, you can get the stand that has a pad instead of spool hookups. Basically, the bottom of the swing arm will rest on the pad as you pick the bike up.
NEPAF4i
03-18-2014 05:21 PM
bluej511
01-11-2008 11:03 PM
