What is the purpose of Chokes are in bikes?
Old Feb 15, 2009 | 02:02 AM
cyberfriend's Avatar
Smile What is the purpose of Chokes are in bikes?
I have seen chokes used in motor cycles and bikes if there the starting problem then we are asked to pull the choke and start and release it back to the position. can you explain why is needed and how it function.
Old Feb 15, 2009 | 02:22 AM
randyjoy's Avatar
Since your question is a verbatum copy of a yahoo question from Yahoo Questions India, you can find the answer there.
http://in.answers.yahoo.com/question...4084527AAvM5QT
Old Feb 15, 2009 | 07:36 AM
CB750's Avatar
Good job on that.
Read any of the replies? Here is I wonder about. I have had a few carbs apart, and have never seen anything like he describes.
First, lets get things straight. Some of the guys who have answered gave a good answer for lawn mowers and very small scooters, etc, but not motorcycles. Most carburatred bikes have a by-pass choking system, which is in reality a miniture carb in built into the side of the main carb. With the butterfly or slide closed, this miniture carb is turned on by the choke lever or ****, which pulls a plunger out, and clears the hole, which goes from the air inlet of the carb, to the body, between the butterfly/slide and engine. There is a tube which drops in to the fuel in the float bowl, this tube has a restriction, to form a jet, to control the flow of fuel on choke. This tube is blocked, when choke is closed. So, for the choke to work, the throttle must be closed, choke on, and start the engine. When started, give a bit more throttle, and as it warms up, slowly push the choke off (closed). This type choke has only been used for the past 40 years or so, on most all Japanese made machines, and a few others. Of course, the old English bikes had the Tickler on the Amal carbs, which allowed you to fill the carb float bowl, before kick starting. Harleys, unless you have an S&S Carb, and the mini stuff are the only bikes with the chokes you guys describe.
Old Feb 15, 2009 | 07:37 AM
Gville George's Avatar
or maybe he is the guy who asked the original Q on yahoo and decided to cover all his bases and ask it here as well.
I like how you say spammer for sure with a question mark after it, if its a question then its not for sure
but ya, kinda weird.
Old Feb 15, 2009 | 11:21 AM
randyjoy's Avatar
Notice the original question was 1 year ago, too.
Bound to be a spammer - who would put those links in their sig.
TheCult
Feb 20, 2012 02:59 PM
regener8ed
Apr 25, 2011 11:07 AM
Silentdrifter
Mar 3, 2011 03:20 PM
madgreek
Nov 19, 2008 06:49 PM
ffingers
Jan 15, 2008 05:49 PM
