What oil?
Old 10-13-2010, 06:49 AM
sjwagstaff's Avatar
Default What oil?
What oil do you lot recomend for a 1988 cbr1000f ?
cheers
Old 10-13-2010, 07:07 AM
kilgoretrout's Avatar
Administrator - Retired
If you do a search you'll find plenty of answers! This question gets asked quite a lot.
I run diesel oil (rotella t synth) but I'm not sure what the UK equivalent would be. Maybe certain Rimula oils, Delo, etc? When I'm not running that, it's Mobil 1 10W40 car oil that is not the energy conserving variety.
Old 10-13-2010, 07:19 AM
sjwagstaff's Avatar
Haynes manual says 10/40 only asked as need quick answer ,as oil is just at bottom of dipstick so wll have to go buy some,was just wondering if its best to use synthetic or semi synthetic,or just a norml 10/40 car oil.
Old 10-13-2010, 08:54 AM
RoadiJeff's Avatar
Senior Member & Lord of The Man Cave
Don't use one that is labeled as energy conserving (most automotive oils) unless you want clutch slipping troubles.
Old 10-13-2010, 01:31 PM
Full synth is generally best, followed by semi, and then regular oil. It's really up to you what you use in your bike.
You can read this if you like. It's a good article.
http://www.calsci.com/motorcycleinfo/Oils1.html
Old 10-13-2010, 01:41 PM
stretch_the_apex's Avatar
i run the mobil 1 4t 10w40 synthetic, really good oil
Old 10-13-2010, 05:00 PM
sjwagstaff's Avatar
cheers, will get some synthetic then and do an oil change .
thanks for advice
Old 10-14-2010, 05:14 AM
sjwagstaff's Avatar
i have some semi synthetic,i dont know what oil previous owner used,so if i put this semi synth i have in just to top up for now would it matter if oil already in was fully synthetic or normal oil?
cheers
Old 10-14-2010, 08:01 AM
nope, won't matter at all.
Old 10-14-2010, 08:19 AM
sjwagstaff's Avatar
cheers,will top up for now and do oil change when i get bike mot'ed.
