What The Hell Happened?!?!?
Old Sep 16, 2006 | 08:35 AM
canadianF4i's Avatar
Default RE: What The Hell Happened?!?!?
Yeah he got it fixed in that case it was his fuel pressure reg. Fuel was leaking down into his cylinders causing the engine to hydro lock and crankcase to fill with fuel.
I'd stop ridin yours if I was you until you get it checked, don't want to be doin 50mph+ and have the bike stall and/or rear wheel lock that could get ugly quick.
Old Sep 16, 2006 | 04:12 PM
D2VW14_20's Avatar
How does that happen???
Old Sep 16, 2006 | 04:26 PM
D2VW14_20's Avatar
Does anybody knowthe members name:?
Old Sep 17, 2006 | 06:48 PM
check out the thread "F4i with 2k miles bogging and running like crap" that will tell you what happened, the members name and what the fix was.
Old Sep 17, 2006 | 06:49 PM
and explain why the FPR would cause it
Old Sep 17, 2006 | 07:41 PM
D2VW14_20's Avatar
Well, so far everything is going normal (not to say nothing is wrong) but it startes up fine, runs fine otherwise. Is there anyway the the idle and maybe starving for gas could have caused if. Or my nephew cranking the throttle while it was parked?
Old Sep 18, 2006 | 09:04 AM
fishfryer527's Avatar
this shouldn't matter with the FI pump not on.
Could your timing or ignition be out of whack? Maybe that could have caused the motor to hiccup.
Let us know if you ever figure it out.
Old Sep 18, 2006 | 05:49 PM
jjkukla's Avatar
ORIGINAL: D2MEclipseGT_600RR
The idle was running really low last night (less than 700) right before I shut it off.
I don't know about the rest of your issues... but idling below 700 rpms is definitely a problem. Owner's manual (on my bike) says to keep it between 1,100 and 1,500 I believe. So I try to have it set right in the middle at 1,300. In addition to having the Honda shop take a look at your bike, make sure your idle-rpm's are up around 1.3k or so.
Old Sep 18, 2006 | 07:03 PM
D2VW14_20's Avatar
Yeah,there re now. I adjusted the idle by the control on the left side and it is fine now. Hopefully it was a one time thing. (Knock on wood)!!!!
Old Sep 18, 2006 | 07:28 PM
rrasco's Avatar
hopefully, otherwise you may not be in your parking lot this time.
