What the heck is on my 1000RR
Old Oct 2, 2006 | 08:22 PM
jhcole100's Avatar
Default What the heck is on my 1000RR
Does anyone know what the gizmo is on my 2006 1000RR exhast. It is in front of the stock can and appears to be some kind of (heat?) valve that has 2 cables going into it. What does it do?? HELP!!!
Old Oct 2, 2006 | 08:34 PM
chainstretcher's Avatar
Admin Emeritus & MVN
Default RE: What the heck is on my 1000RR
It restricts flow at lower rpms for better low end torque according to Honda. I'd say it's probably more emissions/noise related.
Old Oct 2, 2006 | 09:09 PM
jhcole100's Avatar
was that Garmin in your plane or on your bike. It's a shame when your bike goes faster than your plane. I know! $#&#
Old Oct 2, 2006 | 09:11 PM
jhcole100's Avatar
BTW, Does it stay on with a slip on aftermarket can???
Old Oct 2, 2006 | 11:27 PM
Shocktroop's Avatar
Every aftermarket pipe I've sen recomends or requires it to be disconnected. Just remove the cables and tie them up outta the way, but still so that the cables can stil move in and out or else the malfunction light comes on.
Old Oct 3, 2006 | 01:17 AM
zerochickenstrips's Avatar
No aftermarket slip-on pipe retains the exhaust valve. And don't just tie them out of the way. Just take the cables out of the actuator and put them away with your stock pipe. That way you won't ever have to worry about throwing a malfunction code.
Old Oct 3, 2006 | 01:31 AM
voodoochyl's Avatar
Retired Moderator
O2 sensor, I'm sure. I bought an O2 eliminator kit for my Micron exhaust...about $20.00
Old Oct 8, 2006 | 12:52 AM
ORIGINAL: voodoochyl
You're retarded. There is no 02 sensor on a Honda.
Old Oct 8, 2006 | 01:24 AM
fishnride's Avatar
I might be retarded too - the Honda microfiche parts catalog says that the 600RR has had a SENSOR, OXYGEN since at least 2003. 2003-2004, the part number is 36531-MEE-611, while the 2005 SENSOR, OXYGEN is P/N 36531-MEE-D01. Prices are around $112 for the 03-04, and $110 for the 05.
Here is the link to the 2005 muffler assembly with the SENSOR, OXYGEN.
http://www.ronayers.com/fiche/200_04...50&parent=5240
So much for the previous statement that no Hondas have O2 Sensors . . . . . .
Old Oct 8, 2006 | 01:50 AM
doncollins's Avatar
Retired Administrator
Honda does have O2 sensors... on CA bikes. A lot of bikes do.
Chains Garmin avatar is real... he, in a former life, played with 300+ hp bikes.
