what happened?
Old Aug 28, 2010 | 07:49 AM
baxter1's Avatar
Default what happened?
i recently got an exhaust, k&n air filter, and jet kit installed in my 97 f3. I took it to a shop since i didnt trust myself with the jet kit, but when i got my bike back it seemed like someone had lengthed my throttle cable or something because before i had the work done i could open the throttle completely with just a full rotation of my wrist. now it seems that i cant open the throttle completely with almost 2 full wrist movements. can i just pull slack out of the cable to fix this or does anyone suggest another fix?
Old Aug 28, 2010 | 10:47 AM
thrasher572's Avatar
It sounds like your cable has excessive free play. There are a couple of spots to look for correct adjustment. The throttle cables outer jacket is clamped in place at the carb end. If you use a felt marker to mark its current position and then clamp its end farther from the carb you will remove some slack. With recent work on the jetting, my guess is the cable got clamped down too close to the carbs when they were re-installed.
The other spot is the adjusters on the throttle end.
Old Aug 28, 2010 | 05:31 PM
justasquid's Avatar
rotate the throttle all the way closed, then open it. How much does the throttle turn before you can feel the carbs begin to open? As thrasher said... this is the freeplay. You should only have a slight amount of freeplay.
snowboarding82
Jun 12, 2009 12:21 AM
Juggalo_X
Jul 20, 2008 10:49 AM
jlh077464
Nov 13, 2007 08:13 PM
corys35
Jun 22, 2007 02:49 PM
zach1colo
Jun 21, 2007 10:32 PM
