What does the switch on the clutch lever do?
hello,
I'm having the same problem.
I disconnected the ECU for about 2 minutes to move the cables a bit. Now when I start the engine everything is ok, if I put it in gear it's fine too when the kickstand is up (if it's lowered the engine will die right when I put it in gear). The problem is that when I put it in gear with the kickstand up and the I release the clutch the engine stops. It's not from the kickstand because if I put it in gear and the lower the kickstand it will stop with the clutch pulled.
I think the problem is with the clutch switch.
any solutions to the problem? I'm going to try to check the switch and the connection to the ECU.
