VTX Turn Signal Question.
Old Oct 14, 2006 | 01:58 AM
jasonb's Avatar
Default VTX Turn Signal Question.
Alrite now i need some help here.
Turn Signals Are not working.
I have read the manual many many times.
Says to connect the orange with the orange and the blue with the blue.
Did that and everything is connected.
But I am left with the Green wire on both Wires Which is ground.
I turned it on and nothing no turning or nothing. Please let me know if maybe.
I have to do something with the Green Wire I am clueless.
but the Brake Light freaking ROCK!ASSSS
Old Oct 14, 2006 | 04:51 PM
sasakiman's Avatar
Default RE: VTX Turn Signal Question.
If all of your turn signals aren't working get the wiring schematic, trace the wires and find the points that's common to all of the turn signals and check there for a disconnected plug(s) or broken wire(s) or blown fuse. If some of your turn signals work trace the wire to the non-working assemblies. If you're lucky it's only a disconnected plug.
Old Oct 14, 2006 | 10:34 PM
jasonb's Avatar
Fronts are working the only ones that aren't lighting up are the ones that are in the brake light.
The brake light works but the rear signals don't signal.
I grounded the green wire to the frame and still nothing.
Not sure what to do and have been wonderin for a long time.
Old Oct 15, 2006 | 06:45 PM
jasonb's Avatar
I got it it was the connectors they weren't on tight enough. Thanks though.
MuscleswitCBR
Sep 19, 2010 12:45 AM
Mr330i
Jul 19, 2009 06:42 PM
Cun0144
Sep 23, 2008 10:04 AM
slatherson
Mar 13, 2008 11:56 AM
RTOinIraq
Mar 25, 2007 04:07 PM
