Turn Signal Question
Old Mar 25, 2007 | 05:28 AM
RTOinIraq's Avatar
Default Turn Signal Question
Hello
I just bought a 2006 CBR600RR and i have a question. When i bought it the previous owner installed LED front turn signal. Now they flash really fast like one of the bulbs is out but they all work.I figured because LED's dont pull much of a load that it thinks they are burned out. I there any way to fix it or is that the way they work?
Thank You
Cody
Old Mar 25, 2007 | 05:36 AM
dragonium25's Avatar
Default RE: Turn Signal Question
That's the way they work. To slow it down you'll need to add more resistance or use a relay. If everything works fine though, then just leave it, otherwise you'll probably mess something up like every other person on here does with there turn signal mods.
Old Mar 25, 2007 | 05:38 AM
RTOinIraq's Avatar
Thanks for the fast reply. Ill just leave it alone then.
Old Mar 25, 2007 | 04:07 PM
EPNF4i's Avatar
If it's not bothering you then your probably best to leave it alone. But just fyi , when I installed my led's I replaced the relay with an after market one that doesn't recognize the current loss there by eliminating the need for resistors.
MuscleswitCBR
Sep 19, 2010 12:45 AM
Mr330i
Jul 19, 2009 06:42 PM
Cun0144
Sep 23, 2008 10:04 AM
slatherson
Mar 13, 2008 11:56 AM
spidertron
Feb 10, 2007 05:27 PM
