Turn Signal Question
Hello
I just bought a 2006 CBR600RR and i have a question. When i bought it the previous owner installed LED front turn signal. Now they flash really fast like one of the bulbs is out but they all work.I figured because LED's dont pull much of a load that it thinks they are burned out. I there any way to fix it or is that the way they work? Thank You Cody |
RE: Turn Signal Question
That's the way they work. To slow it down you'll need to add more resistance or use a relay. If everything works fine though, then just leave it, otherwise you'll probably mess something up like every other person on here does with there turn signal mods.
Thanks for the fast reply. Ill just leave it alone then.
If it's not bothering you then your probably best to leave it alone. But just fyi , when I installed my led's I replaced the relay with an after market one that doesn't recognize the current loss there by eliminating the need for resistors.
