Turning over not firing
Old Oct 30, 2017 | 12:50 PM
Shaun Lavotha's Avatar
Default Turning over not firing
Hello
​​​​​​I have a 2002 CBR600
This morning I got my bike out for work and it wouldn't start. The day before started fine and rid fine.
It is turning over fine but it won't fire at all.
I tyred bumping with same result, turns over but not fire.
Kill switch isn't up, side stand up, sitting in neutral.
Bike primes as normal when I turn it on. Fuel can be smelled from exhaust. Fuses are fine.
Any other ideas please?
Thank you.
Old Oct 30, 2017 | 03:27 PM
CaBaRet's Avatar
Hi Shaun, looks like your not getting a spark , or your spark isnt good enough, what voltage do you get at the battery when trying to start, other problems could be the usual suspects , that is Clutch switch , Kill switch, Neutral ,Side stand and possibly relays , try swapping the the Headlight Relay with the Engine Stop relay to see if that will start
ekelman
May 6, 2012 10:12 PM
nakedgardener
Aug 18, 2009 02:44 PM
usaf_hess
Aug 21, 2008 01:19 AM
Munson
Jul 14, 2007 10:52 PM
