Turning over not firing
Hello
I have a 2002 CBR600
This morning I got my bike out for work and it wouldn't start. The day before started fine and rid fine.
It is turning over fine but it won't fire at all.
I tyred bumping with same result, turns over but not fire.
Kill switch isn't up, side stand up, sitting in neutral.
Bike primes as normal when I turn it on. Fuel can be smelled from exhaust. Fuses are fine.
Any other ideas please?
Thank you.
Thank you.
Hi Shaun, looks like your not getting a spark , or your spark isnt good enough, what voltage do you get at the battery when trying to start, other problems could be the usual suspects , that is Clutch switch , Kill switch, Neutral ,Side stand and possibly relays , try swapping the the Headlight Relay with the Engine Stop relay to see if that will start
R R
04-03-2008 09:48 PM
