turn signal troubles
Old Mar 7, 2012 | 01:06 PM
s0nofliberty's Avatar
Default turn signal troubles
I just bought an 89 600f, the guy i bought it from wired up some led turn signals but they don't work. When i put the meter on them its only getting 7 volts. Is it supposed to be a constant voltage or is it supposed to go on and off? Also, any explanation for the low voltage? The signals are not lighting up at all.
Old Mar 8, 2012 | 06:13 PM
RoadiJeff's Avatar
Senior Member & Lord of The Man Cave
If they are running lights and not the turn signals they might run at a lower voltage, in which case that would also explain why it is a constant 7V.
Turn signal lights would only get a flashing 12V or they would not flash. Either get a wiring diagram and see what color wires go where or trace the wiring harness back toward the battery and see where it stops being 12V with a multimeter.
You might start at the flasher relay and see if there's a 12V pulse when the turn signal switch is activated.
Old Mar 9, 2012 | 06:58 AM
trippmann's Avatar
i highly recomend getting a shop manual. it makes life ALOT easier and it lists what color wires are and where they go to in the back of the book. good luck.
HondArai
Mar 24, 2014 05:09 PM
MrBlaze
Aug 17, 2009 02:07 AM
Cun0144
Sep 23, 2008 10:04 AM
BRRandon
Jul 27, 2008 04:56 PM
Stephens
Jun 30, 2007 10:33 AM
