Titanium fasteners.
Old Nov 15, 2009 | 06:50 PM
thrasher572's Avatar
Default Titanium fasteners.
Does anybody know of a supplier for titanium fasteners?
I know they are expensive, but has anyone priced stock fasteners lately?
Old Nov 17, 2009 | 12:27 AM
How about this does anybody have a list of the sizes and quantity of fasteners used to build an 08 CBR1000RR?
Old Nov 17, 2009 | 04:39 PM
LBS's Avatar
LBS
http://www.tastynuts.com/
For fairing/screen fasteners I would go for the aluminum. Lighter, way cheaper.
Old Nov 17, 2009 | 09:50 PM
kilgoretrout's Avatar
Administrator - Retired
Which ones are you looking for?
Like the ones for the fairing?
On the fiche, most of them are listed. Then all you really have to do is either buy what you need at a hardware store (if they sell them), or pick them up online.
Old Nov 18, 2009 | 12:40 AM
Titanium Case - Honda CBR1000 08- Complete Kit
The full works everything available for your bike in Titanium! Spoil the one you love... Presented in a stylish case this product consists of Rear Axle Nut , Swing Arm Nut , Front and Rear Brake Master Cylinder Banjo bolts, Bleed Nipples for both Front and Rear Calipers, Front and Rear Disc bolts, Front and Rear Caliper Mounting bolts, Front and Rear Caliper Pad Retaining Pins, Chain Adjuster nut and bolt set, Engine Casing bolt kits, Fairing bolt kit, Front Axle pinch bolts, Handle bar pinch bolt set, Screen kit, Set of 6 sprocket studs and nuts, Top and Bottom Triple Clamp Pinch bolts. That's a lot of weight saving!
£831.91 INC. VAT£723.40 EXC. VATPART No. TICASEHO214
Thanks LBS this is what I was looking for!
Old Nov 18, 2009 | 03:30 PM
skoobydoobie's Avatar
It would be alot cheaper and easier and probly loose even more weight if you walked more and rode less.
Old Nov 18, 2009 | 04:50 PM
Are you calling me a fat bastard? Assumption is the mother of all mistakes doobie.
Perhaps easy and cheap are not what I an interested in. The more unsprung weight you remove from a motorcycle the better it handles. This has been proven countless times. Do some research.
Old Nov 19, 2009 | 07:23 AM
bambam's Avatar
Thanks LBS! I have two projects that were on hold until i saw that link...mad thanks
Old Nov 19, 2009 | 08:24 AM
Krux's Avatar
Settle down guys between you two.
Congrats on the titanium but like some others said we just went to the hardware store yet that's not what your looking for.
Old Nov 19, 2009 | 10:07 AM
LBS's Avatar
LBS
Glad I could help
A bit unfortunate 'though, my very first post here on the forum had a link to a site called "Tasty Nuts"
LOL
