tip over sensor
Old Dec 21, 2011 | 12:28 PM
cuetip's Avatar
Default tip over sensor
anyone tell me where the tip over sensor is on a 99 f4?? by chance is it the box above the headlights, where u have to take the wind screen off to get to it? or is it somewhere else
Old Dec 21, 2011 | 01:01 PM
gotcbr's Avatar
No BAS in F4 like F4i (started in 2001 in fuel injected models). Although the wiring harnesses are similar, the F4 doesn't have the BAS like the '01 & up. It is worth noting that the location of the BAS in the F4i harness is adjacent to the L front turn signal & turn signal relay (same location as F4 just has the additional wiring for the BAS). Also worth noting, you can use an F4i harness but that relay location would go unused on your F4.
Old Dec 21, 2011 | 04:10 PM
cuetip's Avatar
ok gotcbr lol can u explain that slower with no BAS whatever that means lol.... i got that my wire harness is the same as the f4i and thats it
Old Dec 21, 2011 | 06:49 PM
RoadiJeff's Avatar
Senior Member & Lord of The Man Cave
BAS (Bank Angle Sensor) = tip over sensor. Apparently your model year doesn't have one.
Old Dec 21, 2011 | 07:15 PM
cuetip's Avatar
ok so technically how i was to no if it had a sensor, would be to lay it over in 1st and see if it does circles by its self
Old Dec 22, 2011 | 12:59 PM
gotcbr's Avatar
Yep, this...
It is but it isn't. ;-) 2000 was the last year of carbs. In 2001 the F4i became fuel injected. The same basic wiring harness from the F4 was used but additions (like the BAS) were added to accommodate for the additional functions of fuel injection (& also dif front lighting system, dif gauges, etc).
That would not be a good idea. ;-)
Old Dec 23, 2011 | 10:25 AM
cuetip's Avatar
well it was just a thought, since i seen a video of a guy starting his f4i after he pulled the sensor, which to me looked like it was just in front of your left foot, and for the f4 i looked at tip over sensors and i seen that they were up front just above the headlight... so i just thought i would ask, i didnt no if it was in the harness or in the engine, and being that my bike was fully naked i dont think i have one unless i was to look at the wire harness
Old Dec 24, 2011 | 03:22 AM
CJardine's Avatar
Track junkie & modaholic
well They might have re routed it. But unless your stunting it, you want it. its a big safety thing for you bike in the event of a crash.
sly280z
Oct 18, 2012 12:34 AM
BETA
Jul 9, 2012 01:05 PM
sco7tys
Mar 27, 2008 06:41 PM
k.600f4i
Mar 21, 2008 06:12 PM
sixshooter989
Sep 27, 2007 06:51 AM
