Are these what i think they are?
ok, i know this may sound a little off, but keep in mind this is my first bike. On my 87' 1000 i have 2 air valves at the top of my forks near my grips. There is a sticker on my tank that says 0-6 psi. is this for raising/lowering my bike? I have seen things like this on cars and thats what it does, but i dont want to try it and it have some kind of drastic mega perfomance malfunction (lol). any and all help would be thankful.
[sm=dontgetit.gif]
[sm=dontgetit.gif]
It's for softness or firmness. I have them on my 79 GS 1000. I bought a kit that hooked both sides together so they were even. I also have a special gauge that only read to 20psi. If you don't have one, you also need a little pump that looks like a syringe with a Schrader valve mechanism on the end. Mine was made by S&W. Don't use an air compressor.
Why do you want to drop the front end? You could get a shorter, stiffer spring. And you can push the fork tubes higher up the triple clamp. Both will alter your steering by making it quicker, but more twitchy.
