test soon and i got a problem
Old 06-24-2011, 09:56 PM
wrighty92's Avatar
Default test soon and i got a problem
Hey guys, and gals. Having trouble with my LHS indicators. At first the rear globe was blown and that side would flash rapidly when indicating left to aware you the globe was blown. I have replaced the globe with what I had laying around, but it still flashes rapidly?? I was told the globe I used may be a too low wattage and therefor it still thinks it has a blown globe due to the lack of current being drawn to that side? I'm going for my license test very soon and really want to get this working. Any help is greatly appreciated.
Old 06-25-2011, 09:28 AM
justasquid's Avatar
Have you checked the wattage on the bulb you put in? Its very possible its too low of draw and that is your issue. Whoever told you that is more than likely correct.
Check to see what if it matches the bulb you pulled out.
Did you check to make sure your front is ok too?
Old 06-25-2011, 02:55 PM
RoadiJeff's Avatar
Senior Member & Lord of The Man Cave
If you want to verify whether it is the new bulb that is causing the rapid flashing swap it with the working bulb on the right side and see if the problem follows the bulb.
Old 06-25-2011, 08:37 PM
wrighty92's Avatar
Thanks guys, did swapp em round and got higher wattage ones and is all good now. Thanks a lot.
ffingers
01-09-2009 11:44 AM
TheX
12-28-2008 11:00 PM
Nismo6RR714
04-04-2007 03:20 AM
sics15
08-23-2005 11:40 AM
Quick Reply: test soon and i got a problem
