Tach/Digital Display Not Lighting Up
Old May 16, 2010 | 07:35 AM
LB_SpecV's Avatar
Default Tach/Digital Display Not Lighting Up
I turn the bike on to go out last night and notice that theres no illumination on the tach or the dig display. All thats visiable is the constant time readout. The engine starts, blinkers, lights, horn work. Also, my alarm isnt activating. WHICH fuse is it that blew, IF thats what blew?
thanks a lottt
Old May 16, 2010 | 08:36 AM
Michaud85's Avatar
check your fuses man. if it looks blown replace it. im sure you can find out what a blown fuse looks like on the internet if you dont already know. jus tuse some needle noses to pull the fuses out
Old May 16, 2010 | 09:19 AM
Kuroshio's Avatar
Should be one for gauges in the fuse block.
Old May 16, 2010 | 01:26 PM
R Dub's Avatar
October 2011 ROTM
Don't know what bike your on but my F4i was doing the same thing and it was a loose wire in the harness. Fixed that and its been good to go.
Old May 16, 2010 | 01:58 PM
LB_SpecV's Avatar
it was a fuse in the main box under the seat. Also blew the fuse in my gorilla alarm, coincidentally..hopefully.
thanks for the help
Old May 18, 2010 | 10:07 PM
JEFF4i99's Avatar
I've been blowing the same fuse. Every time I turn the key, that fuse pops. All I've done is replace the blinkers, which is odd because the blinker fuse isn't the one popping. Any idea?
I realize there is probably a short somewhere, but any ideas as to where it probably is? More importantly, any atypical suggestions? Like, something that you wouldn't normally think of?
Old May 18, 2010 | 10:50 PM
chuckbear's Avatar
If your alarm is on the fuse that blew, chances are it's something on the alarm. I'd double check that wiring...
Old May 19, 2010 | 05:19 AM
LB_SpecV's Avatar
The alarms fuse blew so I think that caused a chain reaction causing the main fuse box fuse to blow, replaced both, no problemsssss. try a larger load fuse if they keep blowing.
Old May 19, 2010 | 07:43 AM
chuckbear's Avatar
If you have a short there that is blowing your fuses, putting a larger fuse is only going to allow for potential damage to your alarm or your harness. You should really double check the wiring. Obviously something is going on and it's better to spend 20 minutes checking out the wires than having to order a new harness or alarm or who knows what.
Lilkukic26
Mar 4, 2012 02:50 PM
wrighty92
Jun 28, 2011 09:38 AM
flyboy12
May 25, 2009 07:45 AM
eggy9011
May 21, 2009 02:01 AM
shinysideup
Sep 7, 2005 08:11 PM
