Swapping engines
Old Jan 6, 2011 | 01:39 PM
13bpower's Avatar
Default Swapping engines
I am swapping motors in my 954 due to 2nd and 4th gear issues. What else should be looked at or replaced while it is apart?
Here is my list so far.
Valve check
Leakdown test
Tires, chain, and sprockets.
Brake pads
Fork seals if needed
Wheel bearings - TimBucTwo
Is there anything I have missed? What are the common fail points on 954's? The frame and forks have approx 35k. New engine has 16k.
Thanks ahead.
Old Jan 6, 2011 | 01:56 PM
TimBucTwo's Avatar
At 35k I would do the wheel bearings as well.
Old Jan 6, 2011 | 02:51 PM
adrenalnjunky's Avatar
visually inspect clutch.
steering bearing if they aren't smooth
Check the throttle and clutch cables for signs of wear, relube them if they check out. If either have significant drag, just replace.
Check tank for signs of rust/corrosion if you haven't shined a light in there in a while.
Shipleymanx
Sep 13, 2013 05:21 PM
dyracuse
May 31, 2012 12:58 PM
13bpower
Jan 7, 2011 01:01 PM
Willkster
Jun 24, 2010 03:25 AM
teebone
Feb 21, 2007 11:20 PM
