stupid hondas
Old Aug 14, 2005 | 01:11 AM
rocket954's Avatar
Default RE: stupid hondas
haha double checked that.
Old Aug 16, 2005 | 09:28 PM
rocket954's Avatar
ok, still no luck, i think the problem is that it isn't getting spark. so i am getting ready to go take out the spark plugs and see if they are sparking. if they arn't sparking, then where should i go from there?( i hope there not). if they are sparking im going to pull my hair out, because i have no idea what to do next. any one out there with any ideas, please help
Old Aug 16, 2005 | 10:08 PM
sirlimpzalot's Avatar
Are you sure the battery is good?? if not the low voltage may be shutting off the fuel injection...
otherwise if the plugs are not sparking then it might be the ignition system is having issues..either way it needs to visit a shop for inspection
Old Aug 16, 2005 | 10:42 PM
rocket954's Avatar
i am using a jumper pack to star it, so it is getting plenty of volts, also i can hear the fuel pump run. maybe its time for the shop
Old Aug 17, 2005 | 12:39 AM
clean929's Avatar
when you where filling her up was there a gas tanker putting gas back in to the gas station.? sometimes when the gas station is getting there tanks filled it may stir up possible water in those tanks which could cause you while pumping to fill your gas tank with some water.
my guess is to drain the tank and get some fresh gas or get some water remover and see what happens b4 you take the plugs out..
hope that helps. good luck!
Old Aug 18, 2005 | 02:56 PM
rocket954's Avatar
ok ok ok... im a moron. i took everything apart and the fuel pump was pumping, so i lookes down the throttle body and the injectors were spraying properly. so i took out the plugs and each were sparking, but they all looked s@#t. the fuel was greener than normal. so one of my buddies asked if i put dieasel in it. i told him i wasn't stupid. and it wasn't possible, because i thought the island that i used didn't even have dieasel. so we went and checked. sure enough, i knew as soon as i seen it. we drained the tank completly, filled it with gas, redrained it, then filled it up again, cleaned the 30$ plugs and it fired right up. yes i know i'm a moron. [sm=chairshot.gif][sm=chairshot.gif][sm=chairshot.gif][sm=chairshot.gif][sm=chairshot.gif]
Old Aug 18, 2005 | 06:40 PM
chainstretcher's Avatar
Admin Emeritus & MVN
I'll give you this -- you are a real man for admitting it. Most peeps would lie and say the dog ate their rectifier[8D] Glad ya figured it out -- I was stumped big time.
Old Aug 18, 2005 | 06:54 PM
MgA_ODEN's Avatar
Glad you got it fixed
Old Aug 18, 2005 | 08:53 PM
Capone's Avatar
Hey, I live in Central IL too. :P Unfortunately I wrecked my bike... otherwise we coulda rode sometime.
Old Aug 18, 2005 | 10:23 PM
At least you fixed it and posted the problem so we did not sit here wondering what the hell??....Good going and it is a lesson learned I guess huh??
