Stuck oil drain bolt
Old Feb 6, 2006 | 06:48 PM
woogie's Avatar
Default RE: Stuck oil drain bolt
I got some nut/bolt removers for Christmas. They are like EZ-Outs, except that they fit OVER the nut/bolt head, and then you can put a larger socket on it and really crank. That may be what you need. Mine are Craftsman.
Old Feb 6, 2006 | 07:29 PM
chainstretcher's Avatar
Admin Emeritus & MVN
I swear I'm not being a smart *** but are you absolutely positive you're turning the bolt in the correct direction for removal? Reason I ask is that the aluminum the bolt is threaded into will usually strip before the bolt head rounds off or shears. When you do get the new bolt make sure to use a torque wrench to tighten it and avoid any future problems.
Old Feb 6, 2006 | 08:19 PM
patas75's Avatar
righty tighty lefty loosey is the motto i go by. last time i changed the oil i dont remember tightening it that much especially since i dont use any power/pneumatic tools. what's the proper torque setting?
Old Feb 6, 2006 | 11:02 PM
Calkidd's Avatar
Another alternative is to weld another bolt on to the stripped one and use an impact wrench to remove the bolt.
Old Feb 6, 2006 | 11:23 PM
scotty8583's Avatar
Sometimes if you let the bike warm up it may help to loosen. I just can't believe the Vice Grips wont clamp down tight enough!
Old Feb 7, 2006 | 12:31 AM
05Tribal's Avatar
Anyone intervene if this is not a good idea but maybe use a propane torch on the bolt to heat it up then remove it when it is still hot. Also maybe try to use MAP gas instead of propane since it burns hotter.
Old Feb 7, 2006 | 01:24 AM
929_erion's Avatar
Get some rope and tie it to th handle bar and then put a bolt with a pulley on the ceiling(in a crossmember) of garage pull rope through and then tie it off.
Old Feb 7, 2006 | 10:20 AM
no1biscuit's Avatar
929_erion, You have to use aircraft cable for that to work, duh.
The sears tool works pretty good though. I have used them on stuff before but I am shocked that the vise grip doesn't work. Are you using big enough vise grips? (Sorry not saying you don't know how to use them)
Old Feb 7, 2006 | 12:39 PM
johndoe's Avatar
ORIGINAL: 05Tribal
heat make things expand making it harder to remove the bolt.
Old Feb 7, 2006 | 12:43 PM
Tahoe SC's Avatar
that's right mang...if anything, maybe ice cubes...buahahhaha...
you need METRINCH mang!
did it come off? bring it over to mah house and we'll get it off...if you're somewhere in orange county that is.
