Sticky Key
Old Sep 21, 2009 | 06:04 PM
Ruckus1987's Avatar
Default Sticky Key
I have a 92' 600, and over the past couple months the key has become harder and harder to turn to the ignition position. I have to jiggle it for about 2 minutes before it finally turns. Do you think this is a mechanical problem, or will a couple shots of WD-40 fix it, or hurt it?
Old Sep 21, 2009 | 07:43 PM
justasquid's Avatar
WD-40 may work, but you stand the chance of it collecting more dirt and gumming up the dirt that is already in there. It will probably work initially, but can add more problems later.
I would suggest trying powder graphite. You can also use whats called a dry lubricant that comes in an aresol can.. Its basically a graphite spray that will allow the graphite to get into the lock mechanism, just make sure it says graphite on the can.
Old Sep 22, 2009 | 06:54 PM
gotcbr's Avatar
It could just be a piece of gunk in there messing up the monkey-works. Give the lubes a shot first. If no worky-worky, don't temp being out someplace & getting stuck...just replace it.
Old Sep 23, 2009 | 01:30 PM
m_stodd's Avatar
Default new key
One thing you can do is get a new key made. There are some numbers and letters under your gascap that make up your key code. If you take code to a locksmith and get a key made, you can solve or at least narrow down the source of the problem.
I had to do this when I lost my only key (sucked).
Old Sep 23, 2009 | 01:50 PM
scutfargas's Avatar
December 2011 ROTM
+1
graphite works wonders on lock cylinders.
Shadow
Aug 10, 2009 09:26 PM
woo545
Apr 5, 2008 09:31 PM
