Starting issue
Old Dec 9, 2007 | 09:08 PM
Tclipse989gst's Avatar
Default Starting issue
hey guys i have an 05 1000rr that has been sitting up for about a month ( was the last time i started it and was fine )..batery was weak but not dead ..i charged it up still no go...turns over fine but no start..here is what i got so far...no fuel...i turn it on can hear the pump come on and i am pos that the fuel is getting to the rail but whatever allows ther injectors to open is not happening...so i am asuming that i also have no spark...but i have not got that far yet...wondering if anyone has any sugestions...angle sensor?...thanks..tom
Old Dec 10, 2007 | 12:14 PM
Streetdemon's Avatar
I ♥ CBRF
Default RE: Starting issue
Has the battery been tested? Try to jump it and see if thats your problem. I doubt you would have spark issues if the bike was running a month ago but it is a possibility. I assume the fuses have been checked with no issues?
Old Dec 10, 2007 | 03:19 PM
batt checked out ok and all the fuses are good.does the bank angel sensor cut off fuel compleatley or does it just shut down the injectors...or fuel and spark like a camshaft position sensor? im still looking into it
Old Dec 10, 2007 | 04:20 PM
I ♥ CBRF
BAS will cut off the fuel pump and spark.If the bike was just sitting that shouldn't be your problem. Could be a weak spark so the relay may be at fault or you could have a simple issue like the kickstand switch is loose.
Old Dec 11, 2007 | 01:29 AM
demonchild's Avatar
There are diodes in the ignition that are sometimes at fault.
Old Dec 11, 2007 | 01:35 AM
bergs's Avatar
Remove the battery, hit it with a 2 amp charge for no less than 8 hours (10-12 hrs, ideally) and give that a try.
I know you said you charged it, but I'm going to say it was a 10 amp/ 30 minute jobbie and that's not going to do it for the battery.
Take 2 amps for 8-12 hours and call me in the morning.
Old Dec 11, 2007 | 08:10 AM
did a 1amp charge for 12hrs still no go...
Old Dec 11, 2007 | 04:17 PM
I ♥ CBRF
First I'd make sure the fuel pump is working correctly. Open the gas cap, keep ear to the tank and flip the kill switch to run. You should clearly hear the pump prime the rail. Sound good? Move to spark test to make sure thats not the problem.
Old Dec 11, 2007 | 04:33 PM
bergs's Avatar
ORIGINAL: Tclipse989gst
Bummin'
Did mice eat any wires or perhaps get in anywhere? Is your storage 100% mouse-proof?
A month is plenty of time for them to do damage.
Old Dec 11, 2007 | 04:56 PM
98f3greg's Avatar
Take a plug out and hook it up to the wire hold it close to the motor or bare metal and see if your getting any spark. Does the engine smell flooded? Try a shot of ether or starting spray from auto zone with the air filter off and see what you get. Just put it down the velocity sacs with the trottle open then give it a crank.
