Starting Issue
So I went on vacation for about 10 days, I came back and my bike started fine. Its an 03 600rr. I rode for about 15 minutes and stopped. Tried starting the bike no more than 5 minutes after riding and It wouldnt turn over. When I hit the start button it would almost start and then the gauges would fade and then nothing. If I held the button the same would happen followed by a clicking noise. Im not too sure what it is. I would think after a 15 minute ride the battery would be charged enough for a quick stop and start, so thats why Im thinkin its something other than the battery. Maybe a bad starter or alternator....? any one have any ideas. Im going to take the battery out and have it tested just to see.
I guess i should read the entire post before i reply. But as soon as i read that about the clicking, i knew i had the same thing a couple of months ago. Maybe it's the battery since that is the easiest to get to and replace. I always start w/ the easiest and work back. Good luck
the battery is low on it's charge. charge it up and have it load tested. while it's in, do a diagnostic check on the charging system. 03-04 CBR600RRs have been found to have faulty Regulator/rectifier modules, so i'd start there. test it to make sure it functions properly. i doubt it's your stator.
So I got the battery tested and they told me it was kicked. Wasnt holding a charge. Bought a new battery for $100. Bikes starting up fine now. Hopefully its not a charging problem and this battery goes because of it.
ORIGINAL: handshake
