Stalling Problem Help!!!!
Old Jun 15, 2011 | 08:08 PM
sethlx's Avatar
Default Stalling Problem Help!!!!
Ok guys here's my situation. I have a 94 F2 with about 28000 miles on it. Just put a new battery cleaned the carb's, oilchange, new air filter. Just basic maintainance. Rode it around town for 2 weeks and no problems. Took it out on the interstate for my first long ride and 30 minutes into the ride she started to bog down lose power and finally died. There was nothing to indicate any problems. It didnt run hot no other lights came on it just starting loseing power then as I started to slow down killed on me and would'nt restart. After about an hour of letting it cool back down it would start up. It doesnt sound as If it has the same power it did. When you rev it it has a lower exhaust note than before. I checked the battery it holds steady at 12 at idle and at 12-13 at 4000 rpms. I can get the bike started everyday ( it takes several tries right now ) but I don't trust it to ride again untill I get this figured out. Now it started to do this last winter before I put it in the garage so this is not something new that just happened after I did the maintainance. Any help would be appreciated. I am not sure if it's R/R related as it does'nt quite have all the symptoms for that and don't want to just start buying parts that are not needed.
Old Jun 16, 2011 | 12:56 PM
itsme71190's Avatar
Check stator connections n the stator itself. Mine would slowly die till it wouldn't start again cause my stator melted its connecting wires.
Old Jun 16, 2011 | 03:42 PM
sethlx's Avatar
well the thing with mine is it will restart after you let it cool down for about an hour. Thats the strange thing.
Old Jun 16, 2011 | 06:28 PM
itsme71190's Avatar
and its not the r/r???
Old Jun 16, 2011 | 07:17 PM
sethlx's Avatar
It could be the r/r but it doesnt have the same symptoms as the other posts i have read about faulty r/r's
Old Jun 17, 2011 | 07:21 PM
sethlx's Avatar
does anyone think with the symptoms i have given that is truly the r/r?
JamesTSi
Sep 25, 2012 12:09 PM
drax13
Oct 9, 2009 05:27 PM
lloydster
Jun 15, 2009 08:07 PM
Ace_f4i
May 27, 2008 07:54 PM
Cootie
Jan 2, 2006 07:38 AM
