sprockets!
Old Aug 20, 2005 | 03:41 AM
brancart1's Avatar
Default sprockets!
I have heard very differernt things when it comes down to the set-up of the sprockets and the result of doing so. So i figured i would try and put an end to all of it. Ive been reading that alot of people decide on buying the -1 tooth front sprocket and then just leave it at that. Well with the -1 tooth front sprocket you get more acceleration but less top end, right? well the mechanic at the local shop doesnt seem to think so, he told a buddy of mine that by adding 2 teeth to the front sprocket would increase acceleration, but decrease top speed. Could the mechanic be wrong? it just seems like common sense that the smaller the front sprocket the better acceleration you would get because it puts less stress on the motor. So i guess the problem i have is that there are 2 different opinions on how sprockets work in relation to their size. I wish there was like a chart that actually showed different levels of performance based upon what sprocket set-up you have. Ive always thought of buying the -1 tooth on the front sprocket just to get more acceleration, but also to still keep the bike relatively close to its stock powerband. Ive just been hearing two different sides of this, and if anybody has any clue on how this sprocket thing works, let me know. Thanks
Old Aug 20, 2005 | 07:19 AM
Anubis's Avatar
Default RE: sprockets!
The mechanics wrong, [sm=headbang.gif]
1 tooth down on the front will give the desired effect, alot of people put a +2 teeth sprocket on the rear at the same time,
have a look at this................
https://cbrforum.com/m_17497/tm.htm
Old Aug 20, 2005 | 04:57 PM
Turboedsupe's Avatar
I just did -1 in the front and +2 on the rear and it made a big difference in low end power. It doesnt really lag anymore it just gets up and goes. It still wont pull the tire off the ground though by just throttling it. It knocked my speedo way off now though when im going 83 im really going 70mph
Old Aug 21, 2005 | 04:14 AM
Luckydude's Avatar
i heard that taking off one tooth on the front is like putting 3 on the back. its better cause then u dont need to buy a new chain. think of it like a bicycle its really easy that way. at least thats how i do it.
Old Aug 29, 2005 | 02:34 AM
jiveturky's Avatar
the mechanic got it backwards
Old Sep 8, 2005 | 08:51 AM
f4i_reborn's Avatar
I've avoided it altogether because of engine wear. Does anyone have any comments on that?
new06f4iowner
Sep 27, 2010 07:41 PM
pjtime
F2 Tech
May 2, 2010 10:33 PM
04_CBR
Aug 16, 2007 02:24 PM
DS600RR
Jul 18, 2006 10:03 PM
