sprockets
there are a lot of good brands out there. Sprocket specialties, vortex, Driven... All of which are decent.
the one thing you need to consider though if you haven't is that you do not want to replace just a single sprocket. The chain and both sprockets are system that need to be changed together. They wear together, and introducing any new component to the system will create dramatically faster wear of all components due to them not seating together properly. i
If you have less the 3-4 thousand miles on your current set up, you may be able to get away with swapping just one component. But its usually still not recommended to do so. If you have more miles than that, I definately would consider a complete chain and sprocket swap.
As for websites. I usually just use ebay to find the better prices.
