speedo possibly showing higher than actual temp-Cbr600f4i
Hi Guys, my fan always kicked in later than usual. It used to come on at 108-110 C whereas I think should come on between 98 and 104 C as per haynes. I always thought the fan switch was old, but after replacing the switch with brand new oem, i still didn't see the fan kicking in even after 110 C was reached. I now think the temp displayed is higher than usual.
Is there a way current may leak leading to higher than actual being displayed? I know this can happen due to faulty grounds and I am having some grounding issues with the front headlamp where the subloom meets the loom at the connector to the left, but then shouldn't the bike stop completely rather than leak current if that connector was the problem? Besides, I have always had this 'issue' of fan kickin in late -even before I started getting the ground problem.
Thanks
Thanks
That's not my point. my point is that the fan switch should ground and complete the fan circuit between 98-104C by design(of the fan switch).Now this quoted temp range is I think what the temp sensor reads and what is displayed in the speedo and not really the actual temp the fan switch sees(which I think should be lower as it comes further down in the coolant circuit.
Now given that most f4i owners notice there fans come on between 98-104/105 which is a lot earlier than on my bike then the display is giving me a higher temp readout.I ruled out the fan switch being a problem by switching to a brand new switch and totally fresh coolant(engine ice).
Now the higher reading could be due to the temp sensor itself or some electrical issue amplifying the voltage from the temp sensor. I want to understand how this can happen-my guess is some bad ground, but don't know which/where?
I can confirm the temp reading jumps by 1-2 C if I turn the headlamp on and falls down when the it's turned off. This was done with the engine not running, so definitely there's some kind of amplification happening. have someone else noticed this?
Coolant level is fine. I pulled the fairing last week to check again. It's to the brim. The switch is kind of midway, actually more towards the bottom.
dachamp312
05-22-2008 02:05 PM
adam833
06-09-2007 03:14 PM
