temp gauge is not showing any temperature
My 954 shows "--" on the temp gauge at all times. I have checked the wireing and it is hooked up. Does this indicate a faulty temp sensor or is it possible the gauge cluster is to blame? Though I thought it would be a temp sensor issue, this gauge cluster has been on two differentbikes and on both of them it read "--". Why has it been on two bikes? my friend and I are swapping/combining 954s. Both bikes had issues so we are swapping all the good parts on one bike and selling off whats good on the other. Unfortunately by the time I got the bike back up and running,my friendhad already sold the other gauge cluster (which showed a temperature), or we would have used that to test if thegauge cluster was the culprit. Other than showing "--" for temperature, the gauge cluster seems to work fine for everything else.
Anyone experience the same thing?
-Trevor
-Trevor
RE: temp gauge is not showing any temperature
try to talk to someone that might know you there.. i know one service guy and a bunch of salesman and customer service guys at my local dealership.. call and see if you can get a answer bucause they do not need to see the bike if you are telling them a problem like that, but if you can't get a answer iw ill call/go into my dealership and get a answer for you
cBrentb
12-24-2011 07:53 PM
