Speedo Healer set up
Old May 9, 2006 | 05:42 PM
lang1864's Avatar
Default Speedo Healer set up
Hey i was just wondering when you all set up your speedo healer did u set it for the speedometer, odometer, or the best comprimise. Just kinda curious. thanks
J
Old May 9, 2006 | 05:54 PM
MgA_ODEN's Avatar
Default RE: Speedo Healer set up
Speedometer for me.
Old May 9, 2006 | 06:48 PM
Anubis's Avatar
Odo for me, only cos i thought it best to keep that more accurate than the speedo slight offness.
Old May 10, 2006 | 07:25 AM
fisherman's Avatar
Odo for me as I can use the GPS for more 'acurate speed' if need be. Its not out by much though about the same % as when stock
Old May 12, 2006 | 07:47 PM
rjmech's Avatar
If your speedometer is correct your odometer would be logging distance properly also. A Speedohealer corrects both problems if you set it up correctly. However, IF you were to set it to.....let's say show exactly double the speed that you are actually going the odometer would only show 1 mile for every 2 miles you went. Technically, it is possible to correct an incorrect odometer with enough time and riding.
Old May 14, 2006 | 07:51 AM
fisherman's Avatar
My SpeedoHealer clearly shows when doing the calculations that you can set it up for best speedo, best odo or best compromise. I have looked at all three calculations and each value differs. I disagree that if setup for best speedo that the odo is also accurate. We are talking less than 5% but still you're not gonna get both 100%
Mcduuuugal808
Oct 26, 2008 09:46 PM
F3Rider
Apr 2, 2008 02:45 PM
hotwire
May 22, 2006 09:43 PM
7gregory
Apr 15, 2006 01:29 AM
