Speedo Healer
Old Mar 24, 2006 | 12:47 AM
Loomis's Avatar
Default Speedo Healer
I have a 95 F3. I was wondering about the speedo healer if it just adjusts your current speedo?Even if its analog or digital. Or if it provides its own display? my gauge cluster works fine except for the odometer. I have been looking for new or used clusters on ebay they are about $200, locally i found a couple from a salvage shop for $150 but from what i have gathered the spedo healer is like $89 so i was basically wondering if it has its own speed, rpm, odometer display or if it simply "adjusts" your current display. any info that is provided is very appriciated. Thanks in advance.
-Loomis
Old Mar 24, 2006 | 06:41 AM
doncollins's Avatar
Retired Administrator
Default RE: Speedo Healer
It doesn't have a display. It's a little black box with DIP switches and a button that plugs into the factory wiring for DIGITAL speedos. Your bike uses a cable connected to the front wheel, right? That should be accurate. Digital connects to the transmission and all are considered to be off by 5.25% from factory. Then if you change tire brands, size, the tires are worn, change gearing adjust your chain.... you're off more. You would think they have to add one from factory so our mileage isn't off that much at re-sell.
Old Mar 25, 2006 | 12:41 PM
Loomis's Avatar
thanks for the info!
Mcduuuugal808
Oct 26, 2008 09:46 PM
F3Rider
Apr 2, 2008 02:45 PM
hotwire
May 22, 2006 09:43 PM
7gregory
Apr 15, 2006 01:29 AM
