speed sensor problem?
RE: speed sensor problem?
yes,are you losing speedometer and f1 light at the same time?-i am looking a the wiring diagram for
my 54(i dont think that they would be different)-shows 3 wire connector-one is power-to instrument and
sensor,one is for ground,and one goes to both ecm and instrument cluster-this one is why i ask
if both problems are happening at the same time?
double check me with the wire diagram for your bike-should be similar
go through the wiring-check connectors as well as connections,check for a loose ground(doubtful!)
beyond that-try to find out the error code!!-if it is speed sensor-to ecm,it is probably the speed sensor
-you almost need a oscillescope to check the sensor directly-being that it is intermittent,it would be
a b*tch to do-but you would be able to see the spike in the volt pattern-when/if it is acting up
but once more-check the wiring diagram!-if you need further help-i will be on/off the forum
today-i will do my best
o8
o8
my speedo does not work either
I have a Honda cbr 900 RR1998 and my speedometer and odometer only work like 2 min every half hour. and then the speedometer drops to 0 then works again after half an hour.
I measured the voltage coming in the speedometer the pink and black connector the one specified in the book , it measures 5 V when the bike is off or on the on position.
now when the bike is turned on and the speedometer is working , it measures around 2.5 V variable , but as soon as the speedometer stops working, the voltage goes up to 4.9 V stable until the speedo works again, the voltage goes back to a variable 2.5 V .
dunno if that means a speed sensor problem in my case , didnt figure out 100%
here is a link to stephygees site-you will be able to find a service manual for your bike
should have all the info you will need
http://www.stephygee.com/
