Spark plugs..help...
Old Aug 23, 2006 | 06:50 PM
SVTFire's Avatar
Default Spark plugs..help...
When you replace your plugs, is there any one thing certain that you have to do?
Old Aug 23, 2006 | 09:55 PM
kustom98f3's Avatar
Default RE: Spark plugs..help...
What are you actually asking? All you have to do is pull the wires and swap the plugs. Then put the wires back on.
Old Aug 23, 2006 | 10:18 PM
mikequinn's Avatar
Make sure the gap is correct before you fit 'em
The shops always tell you they are pre gapped which is total garbage, nothing is pre gapped
Gap is 0.8 ~ 0.9mm or 0.031 ~ 0.035in for standard, platinm or irridium plugs, get this right and you'll have no problems,
you can't get the plug leads wrong as they are numbered
Old Aug 24, 2006 | 11:42 AM
SVTFire's Avatar
k, i just took the old ones out and put new ones in...i take them out and check the "gap"
thanks
Old Aug 24, 2006 | 12:25 PM
Tahoe SC's Avatar
make sure you do not over tighten them, do not use anti-sieze, and if possible, tighten them to torque specs. if not i belive the manual says something about hand tightening and then 1/4 or 1/2 more or something like that.
baseballkid
Oct 4, 2012 07:48 AM
jvhjgh2006
Jun 26, 2011 02:07 AM
Carbon_cavvy
Feb 29, 2008 08:25 PM
eukanuba517
Feb 19, 2008 04:54 PM
mikey1297
Jul 11, 2006 02:42 PM
