some things don't go to plan !
Old Oct 19, 2021 | 01:56 PM
131commando's Avatar
Default some things don't go to plan !
Hi All, todays job on my 600fk was to strip the cylinder head, valves out for regrind and the missing exhaust studs robbed before I received it replaced with titanium studs things took a turn for the worst when one stud that was embedded in the head that had snapped wouldn't budge when drilled on the pillar drill to within an inch of its life, heat applied, easy out not budging it until crack the aluminium gave way. Luckily there was some thread left once I got the stubborn bit out to fit a longer stud with studlock I have ordered some extreme heat metal putty also to rebuild the broken bit when set. Pics show valves been removed using my cheap chinese compression tool ( not only coronavirus comes out of china ) some useful stuff does too lol.
Valve stem seals removed for new ones on reassembly. Couple of things to add may be of interest note I have an area at the rear of the bench drilled to keep all the valves in order, I use takeaway plastic trays numbered to keep each cylinders bits in order and the tray the head is sat in is half of a 25lt barrel carefully cut to make two parts wash trays sometimes it's the little things that help make a job easier.
Old Oct 19, 2021 | 04:17 PM
Thanks for sharing... sucks about the crack though. Hope you get it sorted out.
Old Oct 20, 2021 | 10:58 AM
Great job and such a neat workshop, wish I had the space. Fingers crossed for the 'putty' fix
Old Oct 20, 2021 | 10:11 PM
74demon's Avatar
A machine shop could probably weld the pieces back together. Better than putty.
malbojah
How To's
30
Sep 11, 2023 03:54 PM
131commando
Feb 2, 2022 02:24 AM
gtcole
Jul 15, 2014 04:09 PM
malbojah
How To's
Nov 24, 2013 10:04 PM
therabbit
May 26, 2007 06:22 AM
