Smokin Joes makes a Strange sound , Anybody ?
Old May 20, 2012 | 12:25 AM
ThreeHondas's Avatar
Default Smokin Joes makes a Strange sound , Anybody ?
Hey I just picked up a cbr f3 Smokin joes , Really cheap , so it has some scuffs and dings but nothing major
It however does make a strange noise , different from my f4
the sound increases when my speed increases but not my rpms , sometimes i cant hear it at low rpms either (yosh pipe , cant really hear anything but )
so the sound is like the squeek of a matress , eeeh eeeeh eeeh eeeh eeeh faster or slower depending on the speed , but when i close the throttle and just roll the sound can be heard and as my speed decreases the noise slows also , not quieter just slower eeeeh eeeeeh eeeeeh , the last owner said he had the front wheel bearing done ,
I guess im wondering what you experts think this strange sound is from
Old May 20, 2012 | 07:00 AM
MadHattr059's Avatar
Either, wheel bearings or sticking caliper, would be my guess.
Try putting the bike up on stand(s) and rotate front/rear wheels,
listening/feeling for drag on the brake rotors.
While it's up double check for tire sidewalls rubbing (although, that's a reach).
Also, try applying the brakes at speed. Does the sound go away? If it does,
most likely brakes, if not wheel bearings go to the front of the list.
I would NOT do any fast/long riding until you do determine the cause.
Catastophic failure of a wheel bearing is a "very bad thing". Potentially leading
to a crash and serious injury.
Good luck, hope this helps, Ern
Old May 20, 2012 | 10:46 AM
Well i was told the front wheel bearing was just done , so it might be the brakes
I have been riding the hell out of it , a 200km drive back to town then another 120km around town , mostly at 180-250kmph
should I stop that perhaps ?
Old May 20, 2012 | 12:04 PM
Being told and actually being done are two different things.
Without knowing what the issue is, you could (best case scenerio) get stranded.
If it's a bearing and seizes completely could be replacing a lot of hardware and/or skin.
I would err on the side of caution, hence my advice.
Ern
Old May 20, 2012 | 01:16 PM
74demon's Avatar
Check the metal clips that the brake pad rides in. they can get bent and drag on the rotor a little. I had this same problem with another members bike. I took the rear brake pads out, rebent the clip, put the pads back in. all fixed in 5 min!
Old May 20, 2012 | 02:59 PM
Ooo, good point Demon, hadn't thought of that.
Ern
Old May 20, 2012 | 06:43 PM
last time I did my rear brake pads on my f4 i fudged the caliper and had to take it to the shop , im usualyy atleast intermediate with these things but i really had no guidence , and pages i could link to or any good step by step for checking that or just for taking off the front brake pads ?
Thanks for the advice so far
Davidth93
Aug 13, 2015 08:18 PM
dcaldwell
Jul 2, 2010 05:54 PM
Kuroshio
Jan 7, 2010 07:24 AM
Butsky
Jun 17, 2008 11:14 PM
