Smoke coming from under
Old Apr 30, 2011 | 05:46 PM
Louizjj1's Avatar
Default Smoke coming from under
Alright im new to the whole motorcycle seen so please try to not degrade me or laugh at me.
I was riding my '05 600rr the other day and I came back and let it sit and run for a minute and looked over and under it something was smoking and leaking. It was coming from a tube by the kickstand that looked like it was running up to the radiator but im not sure because I didnt follow it all the way up. The bike also makes noises when this is happening. I turned the key off and it still did it for about 20 seconds. It sort of sounds like a clicking noise.
Old Apr 30, 2011 | 06:47 PM
jeffjones's Avatar
Check your coolant.
Old Apr 30, 2011 | 08:36 PM
gotcbr's Avatar
As recommended, check your coolant.
Welcome to the CBRForum. Please come on over to the New Member Area & introduce yourself.
Hope you solve your bike's problem quickly.
Old May 2, 2011 | 01:39 PM
highwaypatrol's Avatar
Could be that your engine is running hot and there is a fault in the cooling system. The water seems to have boiled and was sent out of the overflow pipe under the bike. Could be a head gasket fault if not down to low coolant level. Thermostat could also be faulty/stuck in closed postion. Clicking noise was from radiator that was hot and then cooling down after you had switched the engine off!
coldflood
F2 Tech
Jun 8, 2012 04:39 PM
cbaad
Jul 23, 2011 12:25 AM
s1lVa
Mar 31, 2008 11:01 AM
IDL
Aug 22, 2007 12:45 AM
br2819
Jun 18, 2006 01:24 PM
