single air filters
Old Nov 5, 2007 | 02:59 PM
camoweasel's Avatar
Default single air filters
I posted this in 2 different sections with no answers from a while ago. Since this page gets alotmore traffic,I might get more answers. Is there any gain from removing the factory airbox under the gas tank and replacing it with4 single pod filters mounted to each carberator? Would this mod improve airflow significantly or no difference in airflow? I ran the box without the lid once to see if there was any gain and found out it made it harder for the motor to pull air in. I figure though, removing the airbox would take that problem but from doing prior research the airbox isn't as restrictive as I intended it. Is this a worthwile modification or am I just dreaming to much? My bike already has a K&N filter installed when I bought it this summer.
Old Nov 6, 2007 | 03:59 PM
elmer's Avatar
Default RE: single air filters
Air flow is not an issue. The reason it screws things up is because of the amount of vacuum in the airbox. Not worth the trouble, time is better spent on a jet kit or something else.
Old Nov 6, 2007 | 10:27 PM
camoweasel's Avatar
What about drilling holes in the lid itself?
Old Nov 7, 2007 | 07:49 PM
Jason748's Avatar
Wouldn't do it...
When at speed the airbox becomes pressurized.Drilling holes (or taking the the top off) completely negates this effect. If anything look at making the intake tubes larger and smoother on the inside.
Old Nov 7, 2007 | 11:09 PM
camoweasel's Avatar
I already removed the air silencers that were bolted to the top the lid used to quiet down the air. That made alot more room for the filter to breathe. Can you buy bigger or longer intake boots into the carbs?
Old Nov 8, 2007 | 06:42 PM
Jason748's Avatar
Don't know... never looked for them for a "F" You may be able to try an retrofit one from and F2 or F3? or even make your own.
Old Nov 9, 2007 | 08:58 AM
Bumble Bee's Avatar
If you ran the filters like you want to you would have to jet the **** out of the carbs. You will go to lean with the open filters for stock jetting. I would just leave the stock air box alone.
Old Nov 9, 2007 | 11:30 AM
camoweasel's Avatar
I don't mind having to rejet, I just want to know if it will make more power then the stock box?
Old Nov 9, 2007 | 01:32 PM
Jason748's Avatar
No it won't
07ceeberthousand
May 18, 2009 09:33 PM
camoweasel
Oct 16, 2007 05:02 PM
bindelsf2
Mar 20, 2007 07:52 PM
transambird_2000
Oct 16, 2006 12:05 PM
95conv5.0
Jun 7, 2006 04:49 AM
