sidewind
sidewind
Hey is there anything you can do to make sidewind less of a pain in the ***? We've had alot of wind in the last month and once the wind goes more than 20mph it start to get dangerous to ride and 30mph or more makes highway almost impossible. My bike's my ownly vehicle so just don't ride in the wind isn't an option.
RE: sidewind
Evening,
I have an old slab - sided CBR1000 and they are a real pain in the wind. As I was using the bike for a 120mile commute during the summer, I fitted a top box on, and guess what? No more side-wind problems. Now I am not suggesting you fit a top box to an RR or something, but you could experiment with a removeable tail bag. Maybe it would help. I suspect its due to the wind hitting above and below the through-centre line of the bike. Could be worth a try.
Ara
Ara
RE: sidewind
I live about a mile off the Atlantic and side wind in the 20+ is very common. You get use to it and like Anubis said... speed helps. You have more forward momentum to keep you upright. I've actually had the pleasure of a tropical storm... 50+ winds and water up to my ankles. That sucked. Tucking down does help a lot because it reduces the mass from the higher areas. If you sit up straight, your body is higher from the center of gravity and you add a lot of leverage for the wind to use to knock you over.
StockSH
03-11-2008 01:16 PM
