Shifting Issue
Old Jul 13, 2007 | 02:11 PM
ThisisMickey's Avatar
Default Shifting Issue
Hey guys, so I have just been having a slight issue with my 94 F2 when shifting into second gear. I find that if I am accelerating quickly from first gear, when I shift into second gear it drops into neutral... even when I hold my toe up and try to keep it in second gear it slips into neutral then right back into second. I am hoping this can be fixed without taking it to the shop, so any suggestions would be greatly appreciated.
Old Jul 14, 2007 | 02:23 AM
thecannibalchef's Avatar
Default RE: Shifting Issue
i'm told this is normal, but in the manual it lists a bunch of possible causes, from clutch adjustment to shifter linkage adjustment to bent shift dogs. from what you're saying, i assume every other gear works properly, and 1-2 works properly under normal driving conditions. have you tried rev matching, with or without the clutch? if it'll work when you rev match without the clutch, that rules out clutch disengagement issues. is your oil full? if it's overfilled, i know that can cause problems with proper disengagement
userix@live.com
Nov 25, 2012 10:10 AM
Measuredpath
Jun 25, 2009 03:03 PM
iceman_g17
Apr 30, 2008 08:05 AM
StangLou
Sep 1, 2007 08:49 AM
riekky
Jul 15, 2007 07:03 PM
