Sheared manifold stud stuck in head!!!
Old Mar 18, 2009 | 01:29 PM
robjay666's Avatar
Default Sheared manifold stud stuck in head!!!
Hi all. I was attempting to change the downpipes on my cbr600 f3 and sheared one of the studs off in the head! I no..what a plonker!! Has anyone any suggestions on how to get this out please? ive tried penetrating oil and mole grips..that sort of thing but had no joy...it appears to have welded itself in!! There is about 10mm of the stud sticking out. Only other thing i can think of is to try removing the front wheel and drilling it out?? What a pain!! grrr!!! Any help would be much appreciated
Old Mar 18, 2009 | 06:38 PM
89 cbr 600f's Avatar
have u tryed a stud extractor
Old Mar 18, 2009 | 06:45 PM
Rickracer's Avatar
Your best bet would be to find a nut that will slip over the stud, or better yet, thread onto the stud, and then weld the nut to the stud, the heat from the welding will help break the grip of the corrosion, and the nut will give you something to turn it out with , I use that trick a lot on both aluminum and cast iron.
Old Mar 18, 2009 | 10:23 PM
skoobydoobie's Avatar
I like rick's way but you might not have access to a welder. I dunno what the hell "mole grips" are, but put a pipe wrench on it. And heat it up if you can
Old Mar 18, 2009 | 10:41 PM
ichlgo's Avatar
Get this
http://www.restockit.com/3-Piece-Dri...F1&Bvar7=100F1
There are many ways of getting it out, if you do not have any tools or give up. your last choice is to drill it out and retread it.
good luck and keep us posted
Old Mar 20, 2009 | 08:19 AM
Rickracer's Avatar
I do this kinda stuff all the time, for a living, if you have access to a welder, or know someone who does, it will probably take longer to drag the welder out than to do this job. I'm talking literally a 5 minute job (with the fairings already off, of course).
Old Mar 21, 2009 | 12:28 AM
ichlgo's Avatar
Yea. Not everyone has access to a welder but its a good investment. Never know when you would need it =P
robuk
Sep 19, 2013 10:22 AM
xxlostrealmxx
Sep 12, 2012 08:08 PM
robjay666
Mar 18, 2009 05:25 PM
woo545
Nov 5, 2007 12:57 PM
hellboytt
Oct 12, 2007 11:44 PM
