Service Manual wrong??
Old Aug 26, 2006 | 04:47 PM
turbojoe's Avatar
Default Service Manual wrong??
In the service manual in section 8-24 the picture contradicts what it tells you to do when lining up these marks. Can someone explain this to me? I redid my timing last night and went by the picture and not what it actually says to do. Is this a misprint?
Thanks
Joe
Old Aug 26, 2006 | 04:50 PM
turbojoe's Avatar
Default RE: Service Manual wrong??
http://honda-tech.com/zerothread/1733675
Old Aug 26, 2006 | 04:55 PM
chainstretcher's Avatar
Admin Emeritus & MVN
It said to line up the "t" mark with the index mark -- and that's what the picture shows ... I'm not seeing where the descriptions differs from the photo ...
Old Aug 26, 2006 | 05:31 PM
turbojoe's Avatar
the only index marker i saw was at the bottom center... i dont see this inex marker at the top right.. ill take a pic from the actual bike to better explain
Old Aug 26, 2006 | 06:20 PM
mikequinn's Avatar
If your setting the cam timing it's the line next to the "T" that you line up with the cut out on the casing, then the horizontal lines in the cam gears should then line up with the top on Cyl head as it should show in the manual.
if you lined it up with the "T" I think you might be a tooth out.
The marks are ...... "T" line.....line "F"....
The cut out on the casing should be around the 1 '0' clock mark
you are only taking the timing inspection cap off aren't you??
Old Aug 26, 2006 | 06:59 PM
So you're saying your cover is stamped in a different place?
Old Aug 26, 2006 | 07:30 PM
turbojoe's Avatar
no, i just dont see this mark on the top right? But i did line it up as the picture showed. Ill try and get a picture tomorrow.
squidhead
Apr 22, 2012 06:26 AM
Trips
Jul 15, 2009 10:56 AM
transamlt1man
May 16, 2007 01:01 AM
turbojoe
Aug 26, 2006 04:44 PM
aclarkgto
Feb 15, 2006 02:41 AM
