Second Radiator?
Old Apr 6, 2007 | 01:27 PM
Nipz's Avatar
Default Second Radiator?
Well im having problems with my bike overheating and my friend said he heard of some people running a second radiator. Any one else know about this? Links what they use any kind of info would be great thanks.
Nipz
Old Apr 6, 2007 | 01:34 PM
Triax's Avatar
Default RE: Second Radiator?
did you ever change your thermostat, radiator fluid, or make sure their isn't an air bubble in the coolant system? I think running a second radiator would be a huge hassel and not really get you anywhere except a smaller bank account.
Old Apr 6, 2007 | 01:43 PM
Nipz's Avatar
yep.. have done all that.. also install a fan on the out side of the radiator, because there no room in a 91 F2 with a 893cc 900RR engine between then radiator and motor. that help in stop and go trafic but still heat up. Also have new waterpump in there. Only thing i though of doing is have the radiator cored out or aftermaket one if i can find one.
Old Apr 6, 2007 | 03:10 PM
knightslugger's Avatar
sounds like you're going to need a higher capacity radiator. they do make racing radiators for popular racing bikes. check into it. as far as i know, there are no "secondary radiator" assemblies you can buy and bolt on.
Old Apr 6, 2007 | 05:57 PM
jbreit's Avatar
OEM radiators for bikes are pretty cheap....if you have an f2 radiator and are trying to cool a 900rr motor....you are doomed to over heat. Find a 900rr radiator or look for a newer curved radiator...maybe something from aZX or F4 or GSXR....any of them would be $100 or maybe a little less.
aftermarket race radiators are big bucks...
Surf ebay under "heat exchangers"...you might find some nice ones with appropriate inlet/outlets.
Good luck
Old Apr 6, 2007 | 06:05 PM
Err's Avatar
Err
engine ice
Old Apr 6, 2007 | 06:21 PM
fishfryer527's Avatar
Maybe wrap your headers to keep some of the heat away from the radiator. Maybe an oil cooler?
Old Apr 6, 2007 | 07:56 PM
Nipz's Avatar
wrap headers already. found a guy that will let me try his 1000RR radiator out and if it work it will cost me 160$. If not i give it back...... Going to try that over the weekend...
weston123
Apr 30, 2013 06:30 PM
tpgpz
Jul 19, 2010 01:00 PM
Cytotek
Jun 16, 2010 11:10 PM
f3bika87
Oct 25, 2008 08:09 PM
