Screw rear brakes
Well I FINALLY got a set of rear pads and what should be a easy has went to sum beww. caliber is off, now that little tinny flat headed bolt/screw whatever is stuck. I damn near have the head all the way stripped trying to break it loose, and i finally resorted to using some viscripes and clamping on in-between the caliber. and then just smacking it with a hammer.......... i know. so any ideas on how to get this little **** ant loose before i end up with no back brakes. lol
Try a little oil, soaked in a cloth pad over the bolt for a few hours, sounds like the aluminium has corroded (white powder) inside the thread, may help, otherwise, take it to the shop, before you totally root it.
