Riding Question: Turning
RE: Riding Question: Turning
I noticed something no one has mentioned. Look ahead into the curve (Good practice to also use when driving straight). On a course you can see to the end of curves (for the most part) but on the street there are many curves that cannot be seen all the way through. Look as far ahead into the curve as you can. You'll find that your head is turning and when you come out of the curve, the bike and body come back into alignment with the head. What are yall’s thoughts on this?
As far as the push/pull thing goes, I don't even think of that. I look to my exit point in the turn and my hands follow my eyes...I guess, it's not a conscious thing with me anymore. I do ride with a light grip on my bars, I prefer to grip my knees for stability and stay clear of any forceful things on the bars.
When I turn, my weight is forward, but not all on my hands. I put most weight on the tank. When entering the corner, I weight the inside peg (usually by sticking my knee out for the wing effect) then as you feel it get into the lean, put weight on the outside peg somewhat gradually, increasing as speed increases. I dunno if this is the right thing for street, but I have been doing it for so long on a dirtbike I can't stop. I think the concept is the same.
Random side question: I have NEVER used a steering dampner. Do these things actual help? I don't often get wiggle bar, do I really need one?
steering damper do help WHEN you get tank slappers or ride in crappy uneven roads...but what helps more is properly adjusted and serviced suspension. otherwise they just sit there and make steering tight.
too many people get one because they think it's cool or to cover up an improperly set up suspension.
so do you really need one...but it's good to have one...
if you run hard on the track or twists, then you should get one...
nobody's mentioned something very important! You can push pull, twist or tango. Knowing how to make a bike turn is only 10% of taking a curve. You need to know how to read your turn, what line to take through, and to keep it smooth. There are hundreds of books on the subject. But I recommend attending a class(road-racing). The elements you will learn will make you a much safer and more confident rider.
ORIGINAL: Hedp203
ORIGINAL: Hedp203
https://cbrforum.com/m_367048/tm.htm
ORIGINAL: MikeInCtown
One thing that I have to keep realizing is that when they say push right to turn right, they mean push down as in lean the bike to the right. If you follow their example literally, especially with anything other than a sportbike, you'll turn the bars to the left and wipe out.
Countersteering 101: http://www.youtube.com/watch?v=C848R9xWrjc
Here is another video demonstrating it: http://www.youtube.com/watch?v=B8IdTq3_3WI
