08 1000 turning off while riding
I have had my 08 for a couple years now and in that time my bike has shut off about three times while riding. I didn't think much of it, just a glitch or something. But in the past three weeks it has happened three times. It happens when I down shift from second to first. It will just shut off as if the kill switch was hit. The gauge stays lit and I can simply press the ignition button and start it right up. It seems to only happen when I let out the clutch slowly at slow speeds, as if the motor isn't getting enough fuel. It's not a huge deal but an inconvenience and obviously something that shouldn't be happening. Any ideas?
Mods: PCV, full Akro Evo, Pair valve, and some cosmetics
I had a similar problem not too long ago. I tore the bike apart troubleshooting everything on the bike. All connectors properly cleaned and greased back up. Nothing!
Turns out the kick stand bracket was loose. I was having momentary disconnection of the base to the frame (GROUND)!!! take a look there and see what happens. GL.
