Replacing chain. Calipers?!
Old Jan 2, 2013 | 01:06 PM
BlueBerryPie's Avatar
Default Replacing chain. Calipers?!
Hi guys, I'm getting ready to do my first chain [and sproket] change [CBR600F4, 1999], and I've only seen others do it via youtube, so I've got a few questions.
As you can see from the pictures, I bought a DID525 X ring. I was told I would need calipers, so I bought a set today, will these work (i.e., precise enough). What exactly am I going to do with them? I kind of see what people do in youtube but I've no idea what the point is exactly (it's never explained). Some crimpling to a set size?
Thanks, BBPName:  IMG_0963_zps6b228c8f.jpg
Size:  109.9 KBName:  IMG_0962_zpse2455da1.jpg
Size:  135.1 KBName:  IMG_0961_zpsdc3e25df.jpg
Old Jan 2, 2013 | 01:11 PM
gotcbr's Avatar
Yes, you need calipers to measure the flare of the master-link pins once you've installed your new chain & secured w/ master-link. The factory service manual gives you the acceptable flare measurement range for the pins. The manual also takes you step by step thru the process of changing your chain.
For further reference to chain & sprocket replacement...https://cbrforum.com/forum/how-mecha...et-swap-97641/. Its an excellent tutorial.
Old Jan 2, 2013 | 01:53 PM
When I changed my chain, I simply measured the size of the rivet flare on the factory rivet. Then checked to see what is was before flaring the rivet, and then after. I hope this clears up we're they're referring to.
Factory Rivet:
Before Flare:
After Flare:
rdsii64
Nov 2, 2014 08:05 AM
underground-mpyre
Aug 15, 2011 09:25 AM
cblynn04
Mar 27, 2007 04:27 PM
95HondaCBRF3
Aug 3, 2006 07:41 PM
aeroworks
Mar 6, 2006 06:13 AM
