Replacing Chain Adjuster Bolt
Old Jun 9, 2010 | 10:51 AM
TrikyShooter's Avatar
Default Replacing Chain Adjuster Bolt
My right chain adjuster bolt is stripped, therefor preventing my from tightening my chain. I already ordered a new one, but I am not sure how to go about replacing it, or if it would just be better to take it to a shop. Any information is greatly appreciated. BTW it is on a 98 900RR if that makes any difference.
Old Jun 9, 2010 | 04:00 PM
stretch_the_apex's Avatar
shouldnt be to hard hopefully the bolt is just stripped and not the threads inside the swing arm otherwise you'll prob have to make new threads which sometimes means gettin a bigger bolt, but if you put the bike up on a rear stand loosen the chain take out the axle and the rear tire obviously will come off then, the chain aduster block should just pop right out and you can take out the old and put in the new
Old Jun 17, 2010 | 12:07 PM
Any ideas on how to do this without a rear stand? I know I need to get one, but I won't have the money for a while.
Old Jun 17, 2010 | 12:48 PM
chuckbear's Avatar
You're not going to be able to do it without getting the rear tire off the ground as the rear axle runs through the chain tensioner and you'll have to partially remove the axle to swap it out.
lhall6649
F3 Wanted
Oct 12, 2010 07:24 PM
civicblade
Apr 23, 2009 08:24 AM
Rabid
Jun 24, 2008 03:52 PM
Marineborn
Jul 29, 2006 11:21 AM
1000RRSwede
Jul 27, 2006 07:55 PM
