Repaired my fairings but what sandpaper do I use?
I'd use 180 or 220 to smooth it all out. Then 400 to take out the sanding scratches. Then 400 wet, then wet sand with an "ultra fine" scrubby pad. Now clean it real good with some rubbing alcohol/water mix. (much cheaper then prep cleaner) (and dont touch it once its clean, your oily finger prints may f* up the paint job). Now yer ready for paint. Make sure you use adhesion promoter. Spray paint might look good....for a minute. Use auto paint that is designed for ABS.
