Reinstalling rear wheel
The bike needs to be on a stand, push the pads back in the caliber a bit (widen) the gap so the disc will slide in. Take a screwdriver and pry them back inbetween the brake pad material not on the material itself. insert sprocket and rubber cushions, chain then the 2 washers. Get a pry bar and stick under the tire then lift up a extra person would not hurt, i do it by myself. That is the same for a 600rr and a 1000rr. hope this helps
