Reinstalling rear wheel
Old 05-21-2009, 07:41 PM
some guy #2's Avatar
Default Reinstalling rear wheel
Any tips to help this process? Which side do I start first and the hardest part is holding the entire thing up while I'm trying to line everything up.
Old 05-21-2009, 07:58 PM
justasquid's Avatar
Im assuming your bike is on a rear stand. Put the chain on the sprocket, sit behind the bike, take one of your feet and place it under the rear tire so you can lift the tire up into place with your foot. then slide the axle into place.
Old 05-21-2009, 08:20 PM
^There must be some little trick because when I try to put the rotor in the caliper it has doesn't want to go in.
Old 05-21-2009, 08:52 PM
DWT74's Avatar
The bike needs to be on a stand, push the pads back in the caliber a bit (widen) the gap so the disc will slide in. Take a screwdriver and pry them back inbetween the brake pad material not on the material itself. insert sprocket and rubber cushions, chain then the 2 washers. Get a pry bar and stick under the tire then lift up a extra person would not hurt, i do it by myself. That is the same for a 600rr and a 1000rr. hope this helps
jbalber
F2 Tech
10-28-2019 01:09 PM
dyracuse
04-15-2010 04:51 PM
nsx289
05-27-2007 05:25 PM
ericej2344
08-11-2006 02:57 AM
Lgr12
06-21-2006 01:06 AM
Quick Reply: Reinstalling rear wheel
